Is there a API or script to bulk create new users in PagerDuty? I tried https://github.com/PagerDuty/public-support-scripts/blob/master/import_users/import_users.rb which has errors. Also the pypd library is old https://pypi.org/project/pypd/
API script to bulk create users
Hello @ybavn49!
I see you are using the ruby script. Have you followed the instructions here?
If so, I would recommend that you request help from our support team following the steps oulined here. If you give them a CSV file with the requested format they will help you import the users.
Hope that helps!
